I have not used PIPP. But I have been able to used AutoStakkert! (works with Wine on macOS) to debayer the AVI images from ASIAIR.
At the time I tried it, Lynkeos (a macOS native program) unfortunately did not grok AVI, but not only is it macOS native, it has some blind deconvolution (Richardson-Lucy, if memory serves) that AutoStakkert! did not have. Situation could have changed since then.
Lynkeos probably depended too much on the Cocoa framework, which does not support AVI (probbaly because it has to be licensed from Microsoft). You have to use the third party FFmpeg package to import AVI files. Lynkeos may have since done that.
In the meantime, AutoStakkert! has better stacking alignment than Lynkeos :-) :-). When I was playing planetary, I used to first process in AutoStakkert! and then send the stacked RGB files over to Lynkeos. :-) :-).
You have the right scope for planetary. Aperture is key. A 6" SCT simply can't resolve enough planetary detail, and that is the largest aperture I use currently. My 8" SCT has been sitting on its tripod and wheelies, unused for some dozen years now. Too much work to deal with large scopes -- small scopes let me experiment with algorithms just as well.
It is one of the experiments (using Fourier optics) that convinced me that a 6" aperture is the limiting factor with "lucky imaging." The only thing that is better than yours for planetary is a 14" monster.
Be sure to collimate crazily well.
