franco I might need to look into the driver programming. I would prefer, however, that the manufacturer of the mount would do this. They programmed the original indi driver for the Pi on the mount. I will check with them.
I will check, which driver commands for the mount are standardized. It might be possible to make some adjustments to the SlySafari client …
Yes, the driver.xml is probably the way to go for me…
As for the tunneling… it all worked with the demo drivers and the ethernet address in EKOS. But once the mount was connected… the syncing did not work anymore. I will need to double-check this.
Thank you everyone for all of your help. This is highly appreciated!
