I have a Star Adventurer 2i (2i), ZWO 120MM (Z), ASIAIR Plus (ASI), and a Canon R5. None of it seems to want to play together. I've had this trash over a month and haven't been successful yet.
I have the ST4 cable going between the 120MM and the 2i. USB-3 between R5 and ASI. Z is connected to the other USB-3. ASI is also powering the 2i.
A setting I am not sure about is the mount setting. I have this set to On-Camera ST4. When I try to Plate Solve, I get a message the mount can't be found.
From my research, I don't think ZWO has an ASAIR Plus manual available.
I could use some help before I throw the entire setup in the river.
Thanks in advance.
A
