Daveko They connect with my IPhone but not my IPad.
If you are using ASIAIR as the hotspot, see if this works for you. First remove all other network variables, such as disabling cellular, etc on your tablet.
Then open WiFi Settings in iOS, and see if the ASIAIR appears under the Networks menu of the WiFi settings.
You may need to toggle the Wi-Fi off and back on to make it do a new search for WiFi devices.
If you find it, go the the far right of the ASIAIR item where you will see a Get Info icon (an "i" circumscribed in a circle, usually in Blue). Tap on the Get Info icon, and toggle the Private Wi-Fi Address switch off. This will prevent iOS from keeping switching its MAC address. That function often confuses the devices (and even routers) that are not fully compliant with WiFi protocols.
Then tap on Join This Network from the iPad's ASIAIR settings window.
