c131frdave I'd like to image the same thing more than one night
You can, at any time, save the Equatorial coordinates that correspond to the position your mount is currently pointed to by clicking on the Search Field of the small GoTo panel of the mount. (The one with the green GoTo button -- but don't click on the button; just click on the search field).
Then select the My Favorites window from the hamburger icon at the top right of the window.
Tap on the Add button at the bottom right of the My Favorites window. A dialog for Custom Object should appear. Give it a name (up to 50 characters). Then tap on "Use Current Position of Mount". ASIAIR fills in the current coordinates, and you just have to tap OK for that to be saved in My Favorites.
The next evening, just select the Object that you have saved in "My Favorites" and then tap on GoTo.
