In current scenario auto center feature is using time set in telescope section settings.
This is an issue for EFW with Plan mode.
Let's assume that auto center exp time is set to low value (like 2s) and running Plan mode with some dark filters. After meridian flip Asiair fails to recenter (plate solve) cause insufficient number of stars, hence plan will fail to continue.
If EFW is available, auto center feature should use selected filter EAF Exp setting.
