Hi,
I have the Skyhunter mount and ASIair Pro with the new driver installed on it (ASIAIR_Pro_0806_OS). This install allowed me to connect via USB to the mount using the mount setting (CEM120 / 115200 Baud).
Everything works fine (on ASIair side) except the GOTO, ASIair plate solve well but fails to auto-center. It does 4 attempts and display a failure message: "Failed to set". When doing an exposure I can see that the target is off centered.
I have tried to switch on the experimental New plate-solving for dim stars, but no effect.
Any ideas ? Do you guys have the same issue with Skyhunter ?
Clear skies,
Tanguy
