with the setting, Gain 120, 300sec, 10C, I got the weird banding bottom side of the image as below, luckily It does not happen all time for 2x2, but 1x1 binning I got continuously same result, may I get your help
shadowastro Did you try different USB cables, and 12V power supplies?
the camera is connected to pegasus Ultimate Powerbox v2 with the USB cable which is supplied with 294MM, and 12V is also supplied directly by pegasus. How those can affect 1x1 binning images? I mean technically...
But in any case, I will try to change them
regards
shadowastro The pool USB cable or power supply may cause this, so try first. If the problem still exists, please share a raw image with us, thanks.
