I noticed that zwo had this comment regarding amp glow removal and was wondering if it applies. I know dark optimization is a no no but why no master bias and therefore how do you do bias in claibration.
It stated…. Once you have created a master dark frame, calibrate your lights. Unlike CCD cameras, to ensure you properly remove glows, you should only subtract just the master dark. Do not use a master bias. A master flat may still be used.
So what does this mean or do i skip bias?
