franco Shows up the motes amazingly well!
Yes! For cleaning sensors, it helps to use an OTA with a large f-number (or add Barlows) :-) :-).
Notice that the resolution is also drastically reduced. Just use one of the web calculators to compute the Dawes Limit (or the Airy Disk size) when you reduce the aperture to a small pinhole, and you will see why.
Use a neutral density lens if you don't want these effects :-).
Shouldn't the AIR stop guiding when slewing?
Hah, this used to be a real problem with the RST-135 for me. The ASIAIR did not stop guiding when you slew (as you say, it should). So, when you slew, it causes the mount to lock up completely. I had to reboot the mount to make it work again. Unfortunately, it is dangerous to turn off power to a strain wave mount that has no power-fail braking.
I eventually found that I could make the mount not require a power reset by forcing guiding to stop, change the slew rate slider and press on the slew buttons, repeating a couple of times until the mount moves again.
But I have since learned to remember to stop guiding before I execute a slew or GOTO.
I had reported this (guiding not automatically stop -- or at least pause -- when the mount is being slewed) to ZWO about two years ago, but I don't think they bothered to fix the bug. I'm afraid that it will take one of their own mount customers ruin his or her instrument before ZWO pays attention to mount related problems. Just look at how long the numerous AVX bugs (plural) not been fixed. They have no financial interest to fix them. A lawsuit usually fixes financial problems :-).
