Failed third night, second object:
Stopped tracking 11!!! minutes before meridian
NINA
2022-08-31T03:59:47.0260|INFO|MeridianFlipTrigger.cs|ShouldTrigger|261|Meridian Flip - There is still time remaining - max remaining time 00:15:07, next instruction time 120, next instruction Category: Camera, Item: TakeExposure, ExposureTime 120, Gain 100, Offset 250, ImageType LIGHT, Binning 1x1 - and the telescope reports expected pier side pierWest. Automated Flip is not necessary.
2022-08-31T03:59:47.0260|INFO|SequenceItem.cs|Run|206|Starting Category: Camera, Item: TakeExposure, ExposureTime 120, Gain 100, Offset 250, ImageType LIGHT, Binning 1x1
2022-08-31T03:59:47.0270|INFO|CameraVM.cs|Capture|726|Starting Exposure - Exposure Time: 120s; Filter: ; Gain: 100; Offset 250; Binning: 1x1;
2022-08-31T03:59:47.4660|DEBUG|BaseImageData.cs|PrepareSave|111|Saved temporary image at C:\N.I.N.A\e72cb93e-98f7-4f77-b6ee-951942da9646.fits
2022-08-31T03:59:47.4670|DEBUG|Utility.cs|CalculateSunSeparation|96|Sun angle: 122.63
2022-08-31T03:59:47.4670|DEBUG|Utility.cs|CalculateMoonSeparation|43|Moon angle: 158.68
2022-08-31T03:59:47.4680|INFO|BaseImageData.cs|FinalizeSave|163|Saving image at C:\N.I.N.A\LIGHT_30.00s\2022-08-30_M_33\M_33_ATR3CMOS26000KMA_FLEN910_ANGL0.00_B_G100_OFS250_1x1_30.00s_2022-08-31_03-59-11-15.00C.fits
2022-08-31T03:59:47.6250|DEBUG|SessionMetaDataWatcher.cs|GetOutputDirectory|458|MetaDataOutputDirectory is empty, defaulting to image save directory
2022-08-31T03:59:47.6250|DEBUG|SessionMetaDataWatcher.cs|WriteAcquisitionMetaData|69|AcquisitionDetails file name: AcquisitionDetails -> C:\N.I.N.A\LIGHT_30.00s\2022-08-30_M_33\AcquisitionDetails
2022-08-31T03:59:47.6260|DEBUG|SessionMetaDataWatcher.cs|WriteImageMetaData|111|ImageMetaData file name: ImageMetaData -> C:\N.I.N.A\LIGHT_30.00s\2022-08-30_M_33\ImageMetaData
2022-08-31T03:59:47.6260|INFO|SessionMetaDataWatcher.cs|WriteImageMetaData|132|Writing JSON image metadata: C:\N.I.N.A\LIGHT_30.00s\2022-08-30_M_33\ImageMetaData.json
2022-08-31T03:59:48.3630|INFO|ImageSolver.cs|Solve|41|Platesolving with parameters: FocalLength: 910 PixelSize: 3.76 SearchRadius: 30 BlindFailoverEnabled: True Regions: 5000 DownSampleFactor: 0 MaxObjects: 500 Reference Coordinates RA: 01:33:45 Dec: 30° 35' 34" Epoch: J2000
2022-08-31T03:59:49.0500|INFO|BaseImageData.cs|FinalizeSave|163|Saving image at C:\Users\virog\AppData\Local\NINA\PlateSolver\0kejym3v.wcy.fits
2022-08-31T03:59:49.0500|DEBUG|CLISolver.cs|StartCLI|162|Starting process 'C:\Program Files\astap\astap.exe' with args '-f "C:\Users\virog\AppData\Local\NINA\PlateSolver\0kejym3v.wcy.fits" -fov 0.986727 -z 0 -s 500 -r 30 -ra 1.562546 -spd 120.592746'
2022-08-31T03:59:49.3290|DEBUG|SessionHistoryVersionManager.cs|flushQueue|79|flushing session history queue, 1 items
2022-08-31T03:59:49.3290|DEBUG|SessionHistoryVersionManager.cs|flushQueue|84|writing session history, version 299
2022-08-31T03:59:51.8450|INFO|ImageSolver.cs|Solve|54|Platesolve successful: Coordinates: RA: 01:33:44; Dec: 30° 35' 43"; Epoch: J2000
2022-08-31T03:59:51.8460|INFO|CenterAfterDriftTrigger.cs|PlatesolvingImageFollower_PropertyChanged|192|Drift: 0.197859580678636 / 0.75 arc minutes
2022-08-31T04:01:47.8349|DEBUG|ImageSaveController.cs|Enqueue|51|Enqueuing image to be saved with id 641
2022-08-31T04:01:47.8439|DEBUG|ImageSaveController.cs|DoWork|60|Dequeuing image to be saved with id 641
2022-08-31T04:01:48.0009|INFO|SequenceItem.cs|Run|224|Finishing Category: Camera, Item: TakeExposure, ExposureTime 120, Gain 100, Offset 250, ImageType LIGHT, Binning 1x1
2022-08-31T04:01:48.0169|INFO|SequenceTrigger.cs|Run|114|Starting Trigger: DitherAfterExposures, After Exposures: 0
2022-08-31T04:01:48.0169|INFO|SequenceTrigger.cs|Run|114|Starting Trigger: DitherAfterExposures, After Exposures: 7
2022-08-31T04:01:48.0169|INFO|SequenceItem.cs|Run|206|Starting Category: * Instruction Set *, Item: NINA.Sequencer.Container.SequentialContainer, Strategy: SequentialStrategy, Items: 1, Conditions: Triggers:
2022-08-31T04:01:48.0169|INFO|SequenceItem.cs|Run|206|Starting Category: Guider, Item: Dither
2022-08-31T04:01:48.0249|DEBUG|PHD2Guider.cs|SendMessage|753|Phd2 - Sending message '{"id":"99","method":"get_app_state"}'
2022-08-31T04:01:48.3939|DEBUG|PHD2Guider.cs|SendMessage|773|Phd2 - Received message answer '{"jsonrpc":"2.0","result":"Guiding","id":"99"}'
2022-08-31T04:01:48.3939|DEBUG|PHD2Guider.cs|SendMessage|753|Phd2 - Sending message '{"id":"5","method":"dither","params":{"amount":2.0,"raOnly":false,"settle":{"pixels":0.25,"time":5,"timeout":30}}}'
2022-08-31T04:01:48.5479|DEBUG|PHD2Guider.cs|ProcessEvent|936|PHD2 - Lock position set at x:270.694 y:842.401
2022-08-31T04:01:48.5649|DEBUG|PHD2Guider.cs|SendMessage|773|Phd2 - Received message answer '{"jsonrpc":"2.0","result":0,"id":"5"}'
2022-08-31T04:01:50.0629|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.91
2022-08-31T04:01:50.6939|DEBUG|StarDetector.cs|ModelPSF|327|Modeling PSFs using a parallel partition size of 100 and a pixel scale of 0.852258979658332 arcsec/pixel
2022-08-31T04:01:52.6218|INFO|HocusFocusStarDetection.cs|Detect|367|Average HFR: 2.22720103979638, HFR σ: 0.374465842183991, Detected Stars 953
2022-08-31T04:01:52.9309|DEBUG|Utility.cs|CalculateSunSeparation|96|Sun angle: 122.64
2022-08-31T04:01:52.9318|DEBUG|Utility.cs|CalculateMoonSeparation|43|Moon angle: 158.69
2022-08-31T04:01:52.9328|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.65
2022-08-31T04:01:53.5228|DEBUG|BaseImageData.cs|PrepareSave|111|Saved temporary image at C:\N.I.N.A\fee7acc8-79ea-4f92-9139-5fb78b9b3786.fits
2022-08-31T04:01:53.5238|DEBUG|Utility.cs|CalculateSunSeparation|96|Sun angle: 122.64
2022-08-31T04:01:53.5248|DEBUG|Utility.cs|CalculateMoonSeparation|43|Moon angle: 158.69
2022-08-31T04:01:53.5258|INFO|BaseImageData.cs|FinalizeSave|163|Saving image at C:\N.I.N.A\LIGHT_120.00s\2022-08-30_M_33\M_33_ATR3CMOS26000KMA_FLEN910_ANGL0.00_L_G100_OFS250_1x1_120.00s_2022-08-31_03-59-47-15.10C.fits
2022-08-31T04:01:53.6148|DEBUG|SessionMetaDataWatcher.cs|GetOutputDirectory|458|MetaDataOutputDirectory is empty, defaulting to image save directory
2022-08-31T04:01:53.6148|DEBUG|SessionMetaDataWatcher.cs|WriteAcquisitionMetaData|69|AcquisitionDetails file name: AcquisitionDetails -> C:\N.I.N.A\LIGHT_120.00s\2022-08-30_M_33\AcquisitionDetails
2022-08-31T04:01:53.6158|DEBUG|SessionMetaDataWatcher.cs|WriteImageMetaData|111|ImageMetaData file name: ImageMetaData -> C:\N.I.N.A\LIGHT_120.00s\2022-08-30_M_33\ImageMetaData
2022-08-31T04:01:53.6158|INFO|SessionMetaDataWatcher.cs|WriteImageMetaData|132|Writing JSON image metadata: C:\N.I.N.A\LIGHT_120.00s\2022-08-30_M_33\ImageMetaData.json
2022-08-31T04:01:54.3608|INFO|ImageSolver.cs|Solve|41|Platesolving with parameters: FocalLength: 910 PixelSize: 3.76 SearchRadius: 30 BlindFailoverEnabled: True Regions: 5000 DownSampleFactor: 0 MaxObjects: 500 Reference Coordinates RA: 01:33:45 Dec: 30° 35' 34" Epoch: J2000
2022-08-31T04:01:54.4888|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.51
2022-08-31T04:01:55.1188|INFO|BaseImageData.cs|FinalizeSave|163|Saving image at C:\Users\virog\AppData\Local\NINA\PlateSolver\maq2bckl.2tf.fits
2022-08-31T04:01:55.1188|DEBUG|CLISolver.cs|StartCLI|162|Starting process 'C:\Program Files\astap\astap.exe' with args '-f "C:\Users\virog\AppData\Local\NINA\PlateSolver\maq2bckl.2tf.fits" -fov 0.986727 -z 0 -s 500 -r 30 -ra 1.562546 -spd 120.592746'
2022-08-31T04:01:55.9318|DEBUG|SessionHistoryVersionManager.cs|flushQueue|79|flushing session history queue, 1 items
2022-08-31T04:01:55.9318|DEBUG|SessionHistoryVersionManager.cs|flushQueue|84|writing session history, version 300
2022-08-31T04:01:56.0118|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.42
2022-08-31T04:01:58.0458|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.4
2022-08-31T04:01:58.9128|INFO|ImageSolver.cs|Solve|54|Platesolve successful: Coordinates: RA: 01:33:44; Dec: 30° 35' 42"; Epoch: J2000
2022-08-31T04:01:58.9128|INFO|CenterAfterDriftTrigger.cs|PlatesolvingImageFollower_PropertyChanged|192|Drift: 0.197045800839918 / 0.75 arc minutes
2022-08-31T04:01:59.5678|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.36
2022-08-31T04:02:01.0818|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.31
2022-08-31T04:02:02.6018|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 0, Distance: 0.24
2022-08-31T04:02:04.6258|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 2, Distance: 0.21
2022-08-31T04:02:06.1658|DEBUG|PHD2Guider.cs|ProcessEvent|887|PHD2 settling started. Time: 3, Distance: 0.21
2022-08-31T04:02:07.6888|DEBUG|PHD2Guider.cs|ProcessEvent|898|PHD2 settle completed
2022-08-31T04:02:08.1298|INFO|SequenceItem.cs|Run|224|Finishing Category: Guider, Item: Dither
2022-08-31T04:02:08.1298|INFO|SequenceItem.cs|Run|224|Finishing Category: * Instruction Set *, Item: NINA.Sequencer.Container.SequentialContainer, Strategy: SequentialStrategy, Items: 1, Conditions: Triggers:
2022-08-31T04:02:08.1298|INFO|SequenceItem.cs|Run|206|Starting Category: Filter Wheel, Item: SwitchFilter, Filter: L
2022-08-31T04:02:08.1308|INFO|SequenceItem.cs|Run|224|Finishing Category: Filter Wheel, Item: SwitchFilter, Filter: L
2022-08-31T04:02:08.1388|INFO|SequenceTrigger.cs|Run|114|Starting Trigger: DitherAfterExposures, After Exposures: 0
2022-08-31T04:02:08.1388|INFO|SequenceTrigger.cs|Run|114|Starting Trigger: RestoreGuiding
2022-08-31T04:02:08.1398|INFO|SequenceItem.cs|Run|206|Starting Category: * Instruction Set *, Item: NINA.Sequencer.Container.SequentialContainer, Strategy: SequentialStrategy, Items: 1, Conditions: Triggers:
2022-08-31T04:02:08.1398|INFO|SequenceItem.cs|Run|206|Starting Category: Guider, Item: StartGuiding
2022-08-31T04:02:08.1398|DEBUG|PHD2Guider.cs|SendMessage|753|Phd2 - Sending message '{"id":"99","method":"get_app_state"}'
2022-08-31T04:02:08.1698|DEBUG|PHD2Guider.cs|SendMessage|773|Phd2 - Received message answer '{"jsonrpc":"2.0","result":"Guiding","id":"99"}'
2022-08-31T04:02:08.1698|INFO|PHD2Guider.cs|StartGuidingPrivate|464|Phd2 - App is already guiding. Skipping start guiding
2022-08-31T04:02:08.1698|INFO|SequenceItem.cs|Run|224|Finishing Category: Guider, Item: StartGuiding
2022-08-31T04:02:08.1708|INFO|SequenceItem.cs|Run|224|Finishing Category: * Instruction Set *, Item: NINA.Sequencer.Container.SequentialContainer, Strategy: SequentialStrategy, Items: 1, Conditions: Triggers:
2022-08-31T04:02:08.1938|DEBUG|AutofocusAfterHFRIncreaseTrigger.cs|ShouldTrigger|214|Autofocus condition extrapolated original HFR: 2.20703555588585 extrapolated current HFR: 2.22894002808695
2022-08-31T04:02:08.1938|INFO|SequenceItem.cs|Run|206|Starting Category: Camera, Item: TakeExposure, ExposureTime 120, Gain 100, Offset 250, ImageType LIGHT, Binning 1x1
2022-08-31T04:02:08.1948|INFO|CameraVM.cs|Capture|726|Starting Exposure - Exposure Time: 120s; Filter: ; Gain: 100; Offset 250; Binning: 1x1;
2022-08-31T04:04:08.9866|DEBUG|ImageSaveController.cs|Enqueue|51|Enqueuing image to be saved with id 642
2022-08-31T04:04:08.9966|DEBUG|ImageSaveController.cs|DoWork|60|Dequeuing image to be saved with id 642
2022-08-31T04:04:09.1576|INFO|SequenceItem.cs|Run|224|Finishing Category: Camera, Item: TakeExposure, ExposureTime 120, Gain 100, Offset 250, ImageType LIGHT, Binning 1x1
2022-08-31T04:04:09.1736|INFO|SequenceTrigger.cs|Run|114|Starting Trigger: DitherAfterExposures, After Exposures: 0
2022-08-31T04:04:09.1736|INFO|MeridianFlipTrigger.cs|ShouldTrigger|200|Meridian Flip - Telescope is not tracking. Skip flip evaluation
