@andrew s#58299 I find the occasionally I get speckle noise near the centre of the frame.
Try running the camera without turning on the cooler, and if the speckles are consistently absent, then it is very likely to be caused by ice (ice tends to form near the center of the sensor).
If the cooler has nothing to do with the speckles, the problem is elsewhere.
