I was inspecting pixel values from my ASI178MC in RAW16 format and I noticed that the two least significant bits (LSBs) were not always zero. This is unexpected, since the ADC resolution of this camera is (at most) 14 bits. On further investigation, I found that this only happens when I capture on Linux but does not happen on Windows.
Here are histograms showing the frequency that each bit is set. For each stem, a value of 1.0 would mean the bit in that position is set (equal to 1) in every pixel in the frame, and a value 0.0 would mean the bit in that position is never set (always 0).
In the Windows capture, as expected, the values of bits 0 and 1 (the two LSBs) are always zero, leaving 14 bits of actual data from the sensor. In the Linux case, bits 0 and 1 are not always zero. I wonder if perhaps there is a bug in the Linux version of the driver where the two LSBs contain uninitialized data?
I used ASICap for this experiment on both Windows and Linux, from ASI Studio version 1.6.3 downloaded and installed today.
