The focuser shaft on the Celestron SE6 (late model) measures 13.18mm in diameter.
Will the bracket kit for the Celestron SE8 work on the SE6? Are the bracket holes and screws compatible with the SE6?
The ZWO EAF Bracket for Celestron C8 and C9.25 SCT Telescopes # ZW-EAF-C8-C925 has two flexible couples (12.8mm and 22.20mm), so I will need a different flexible couple or drill out the smaller one, or add a spacer for the larger couple.
My alternative is to go with the SCT GSO focuser. Has anyone successfully (securely) installed the standard bracket bracket on the SCT GSO focuser?
