w7ay
Yes. If you take the time to read the documentation the FW Updater is intended to be used to update the firmware of ZWO products with motors.
The updater scans and finds the model of the product and firmware version before you are allowed to choose the .hex file to use to flash the decice.
The updater also requires an older version of some Microsoft files which I installed per the documentation afterwhich the updater now gets to this point.
So not wow, just standard procedure. But I'm disappointed that the update is not working as I also have another ZWO EFW and a couple of ZWO EAF to update.
