yes, the horizontal lines is there. but should not be so visible
there is an "Anti column noise" function of the sensor and which is enabled automatically when start.
but this function may runs not well if you start long exposure like some seconds when just open the camera.
there is another way to activity it just enable or disable "Flip Horizontal". I think you can have a try.
I attached a dark frame with my ASI120MM.
Flat frame has some horizontal interference-alike bands is because of the daylight lamp which use AC.
I think it will gone if you test at daytime without the lamp
attach a TEC to the back of the camera is not very effective but the simplest way.
the cold figure touched the sensor in our new cameras with ST4.
