I had EAF issues for a while and finally got that working after a firmware update. However, since then, my EFW has failed to connect. I've tried absolutely everything from unplugging everything and powering one thing on at a time, starting with the filter wheel, to plugging into different USB ports (both from my ASI1600mm-cool and my ASI Air, to buying new cables, to just tonight trying a brand new ASI Air Pro. I'm STILL having the exact same issue. Is my filter wheel dead?? I did absolutely nothing to it but, after the firmware update on the focuser, it's no longer recognized. I've lost so many clear nights to this issue. Please help!
    SaraMcAllister
    Did you try to directly connect the EFW to PC? please try different cables and check if there is a new device appear in the device manager, and do you hear the connection sound?
    Write a Reply...
