Hello!
I recently bought myself an Asiair Pro and now after my first imaging session I've run into problems...
Somehow I have really strong oscillations (on both dec. and RA) that won't stop. Here's my guide log:
https://drive.google.com/file/d/12OgbdK7NSElp8xVDbtj4OmKznNSApEre/view?usp=sharing
I think it instantly becomes clear where the problem lies...
Note that the first 2 logs of only a few minutes are not representative, those were only tests.
What usually gets said when someone's log looks like mine does they are told that their aggressiveness is set too high, which might be the case here, though I find it weird that I used those some values for agr. with my laptop (pre-asiair) and they worked like a charm. And as the Asiair uses PHD2 for guiding I figured my old settings would work, but this doesn't seem to be the case
Also, it's worth mentioning that the Asiair does no calibration (not even the first time I used it) when I click the crosshair/calibration/start guide button, so maybe (as has been suggested by other people) I have a setting turned on that takes the previous calibration.
Also, how can I change the MinMo (x/y) on the asiair?
Hope somebody is able to help 🙂
Clear skies,
Tim
