Swizerlan I want to transfer someone elses image from the library on my iphone to asi ai
ASIAIR v2.0.0 (currently Beta) allows you to copy files into the ASIAIR's Samba server even when logged in as Guest. The easiest way is, for example, create a folder inside the "ASIAIR" folder (where you find Autorun, Live, log, Plan, Preview and Video folders) in the ASIAIR's USB drive, and copy a FITS file into that new folder. Do not copy into the udisk or sd folders, that is some old remnent that ZWO never got rid of (and confuses new users to no end).
You can then open this FITS image by navigating to it using ASIAIR's Image Management, starting at the new Folder that you had created. (And use GoTo to move the mount to the center of this image.)
You can of course also copy the FITS file into any of the existing folder as long as you won't later confuse it with any of your existing images.
Older ASIAIR versions' Samba server do not give write permission (I do not remember if v1.9.2 allows it), so you could not go through Samba -- if so, you will need to plug the ASIAIR's USB drive into your computer and copy it that way.
