Hello. What are the default settings for the wred and wblue parameters in the 2600MC driver? Is it 50/50? If not, is there a way to change the values to 50/50?
Thank you Mike
drmikevt Some software lets you set these values. Others do not. If we can not set the blue/red values manually, what is the default setting?
drmikevt The default setting is WR52 WB95, you can set 50/50 in the software if it allows, and this value should be remember in the software.
Tech@ZWO is there a benefit to setting to 5050? Would the default values better compensate for the matrix?
MikeMcCall60 White balance is just for making sure grey looks grey and not blue or red or green or yellow. Your eyes will tell you when you got the white balance right - there won't be any colour cast in the image. Just adjust the sliders the way you like.
