Hello,
I tried to connect the camera to my telescope via ST4 port. The connexion is established but when I try to control the telescope nothing happens. I tried with Firecapture and AsiStudio. What did I miss ? Thank you. Regards, Philippe
PhMur Please try other ST4 cables first. Also, do you have other camera has ST4 port? you can try other cameras.
No, I only have this one. I also only one cable therefore I'm not able to try another one
PhMur Need to rule out the problem first. The problem may be on the cable, camera or the port on your mount.
I tested the cable is ok. I don't know how to test the port of the mount as I only have this camera.
