Hi all,
I recently got the Asi 120mc and I am trying to use the default image capture software from Zwo as well as Sharpcap. I have been getting black screens most of the time and sometimes (rarely) I do get the camera to start up...is there something that I have not done correctly?
Thanks!
Try FireCapture and check if it will work correctly on lower "USB traffic" values.
yes, you can try to lower the "USB Traffic" value
its name in amcap is "Auto FPS Adjust" under the "video input filter" menu
also you can try another usb port or plug the USB line to the back of PC instead of the front
Thanks all for the quick reply! Ok I will give it a try and let you guys know if it works!
Cheers!
