tareqphoto Is the camera ASI294MC Pro has "unbinned" mode same as the mono version?
I am not sure an unbinned color ASI294 will be that useful. Remember that each Bayer component will be covering a 2x2 area of the unbinned pixels.
See Sony's data for the IMX294 sensor here:
https://www.framos.com/en/news/sony-launches-highly-sensitive-4-3-cmos-sensor-for-4k-surveillance
Check out the CFA (color filter array - i.e., Bayer pattern) about half way down the page.
At the minimum, you will need some special software to deBayer it. And after deBayering, you will not get better image resolution anyway. Possibly the use of Drizzing will help recover the resolution, if you have many, many subframes for the Drizzle algorithm to work with.
