redpine42 Is there no way to reset the ASI Air plus back to it's original state?
Supposedly, holding down the black reset button for longer than 5 seconds will bring back the original "factory" firmware.
The next time you connect the box to an ASIAIR app, the app will update that factory version with the current version of the firmware.
Your problem sounds like the app in the tablet is crashing, though. Check to make sure you have enough RAM in the tablet. ASIAIR 2.0 seems to eat up more RAM than previous versions. You can help it by powering the tablet down, and then rebooting it, and then with no other app running, try ASIAIR.
