Hi everyone,
in firecapture to take a color shot it's enought flag the bebayer option on the right? and then modify the value in setting for red and blue. I've done this, it's enought or i've to set some video codec?
then... i've tried to take B/w shot but when i use regitstax the final image is bad because ther is the bayer filter
yes, you can preview the image enable debayer and adjust the white balance
it can save lots of disk space if you save as undebayered raw format.
but you need to debayer it again when processing
just select the correct pattern
