tbhausen
Do I turn on tracking before or after polar alignment?
Tracking turns on automatically after first successful GoTo - no need to turn it on manually
I'm setting up pointed to magnetic north with counterweight down. Do I need to somehow tell the ASiair this is "home position" before polar aligning?
"Home Position" is whatever position the mount is found to be when AA starts up. Before turning on anything, put your mount manually in the desired position. Turn on mount then turn on AA.
After polar alignment succeeds (when RA rotates 60 degrees west), if I go to Polaris, it's usually in my scope's 1.8 x 1 degree FOV, but centering fails. So I think I'm missing a step somewhere...
Plate solving is not working very well (sometimes not at all) near the NCP
