See title. I don't need the accessories, just the motor, and I think there's no such option in the store.
The use case here is having a Samyang/Rokinon 135mm rig for wide field using 3D-printed rings and what-have-yous (or various plates, gears, and belts kit-bashed together) where I mount everything, then a standard telescope for something longer. I don't want tear down one OTA rig if I'm going for a target that's not a good fit for the OTA that's currently set up. Everything else - filter+camera assembly, guidescope, etc - are modular and easy to remove and mount by design.
Thanks!
