Nicholas Can I just ask as to my original question do you know why ZWO says to use a usb 3.0 camera/guider and not the 120mm/mc ?
ZWO no longer supports the older USB 2 cameras with the USB 2.0 Type B connectors. They are not really that old, but ZWO has abandoned support for it (probably too many problems). If it does not work, you are on your own (i.e., throw it in the trash).
The ones with USB 3.0 (blue) Type B connectors are supported.
Also supported are the "mini" cameras that have a USB Type C connector supporting USB 2 protocol. Note that it does not support USB Type C connectors with Thunderbolt protocol; so you cannot connect the USB C from the camera directly to the USB C Thunderbolt connector on a modern Mac computer -- you need to go through a USB C hub.
(USB C is simply a connector standard -- USB C can support USB 2, USB 3, DisplayPort, Thunderbolt, and USB PowerDelivery protocols. If one end only supports USB 2 and the other end only supports Thunderbolt, you will need something like a USB Hub in between that can convert USB 2 to a USB 3.)
The difference between USB 2 and USB 3 is that a USB 3 connector has 5 extra pins (you can see it deep inside a blue connector). One pair of pins is for receive data, the second pair for transmit data (so fully duplex), and one pin for the shield drain. USB 3 depends on the Power and Ground pins of the original USB 2 pins. USB 2 has 4 pins, the aforementioned power and ground, and a pair of wires for half duplex data (which contributes to why it is so slow).
