Hi, the site (http://www.zwoptical.com/Eng/Cameras/ASI120/features.asp) says no FPN but I guess it would be more fair to say low FPN. I'm 100% sure that "Column Correction" feature kicked-in (I saw frames without it and the column-wise FPN is much much worse and anyway I did some HW flips before acquiring). I'm attaching the mean of 56 10" darks with histogram equalized (so the contrast in really enhanced), a single frame 10" and the result of stacking 63 frames. Unfortunately there is some more vertical banding. I just subtracted the mean dark from the single frames.
I'm asking more experienced astro imagers: a flat field could help? It's quite some hours to build a flat field box and I don't see vignetting so I'm asking first before starting. :-) Other suggestions? The bars don't seem to be regular, so I don't see how one can use a notch Fourier filter. More darks?
Thank you very much!
PS. Haven't seen much FPN on the ASI120MC bu until now I worked only with 8 bit (Haven't written my debayer code yet).
PS. attachments don't work, it says "Sorry, the board attachment quota has been reached" so:
dark mean: http://farm3.staticflickr.com/2636/13078605354_9ef2e39495_o.png
a frame: http://farm4.staticflickr.com/3172/13078608084_fc49d657c9_o.png
final image: http://farm8.staticflickr.com/7328/13062814144_5bcf95e32f_o.jpg
ASI120MC example: http://farm3.staticflickr.com/2166/13066237494_c6458759d5_o.jpg
