arakasi I'm in NSW, too around S 34°, E 150°
I use this tool - https://www.bintel.com.au/astronomy-weather/ - along with the Clear Outside, Nightshift and Good To Stargaze (free version) apps - along with the BOM weather app - to determine if the night is good to set up my equipment.
Tuesday night might be good. Wednesday night is looking good, too. At this stage anyway.
I haven't noticed this issue myself but, then again, when I do the PA routine I haven't tested to see if just leaving it and hitting refresh would do anything. I use All Sky Polar Alignment (ASPA) as well (don't think I get the best view on the SCP).
During the late afternoon, I set my tripod with the N pointing to True South, load it up with gear, balance it, make sure it is in the Home position (counterweights down), turn on ASIAIR, connect to it with the ASIAIR App, go past initial screen, turn on camera cooling to 0°C, then turn on mount, then enable mount in ASIAIR APP.
I then get a rough, daytime, focus on a distant object. Return everything to Home. Put lens cover on scope. Turn off camera cooling and shut down ASIAIR in App. Wait a couple of minutes. Power off ASIAIR. Power off Mount.
Once night hits - power on everything in the same way as before. Once camera has stabilised at 0°C - improve the focus a bit. The do PA routine with ASPA. When I get the screen which tells me how far off I am I just do the "slight adjust - wait 5-10 seconds - refresh" cycle until I get a smiley face (don't bother with trying to get it 0) then hit Finish. Return mount to Home position. Then Sync Mount (under Mount settings). As far as I can tell - mount tracking isn't on during the PA routine - because mount tracking is only turned on once the PA routine completes (I think).
I can then find a star to track, go into Focus mode, refine my focus, return to Home, then Go To my target(s) for the night.
ASIAIR: ASIAIR Plus (32GB - Raspberry Pi based version AFAIK)
Mount: HEQ5 Pro (no Hand Controller - USB 2.0 port on ASIAIR Plus directly connected to the HC Port on the mount using this EQDIR/EQMOD cable - https://www.bintel.com.au/product/shoestring-usb2-eq5-interface/)
Camera: ASI294MC Pro (cooled to 0°C connected to USB 3.0 port on ASIAIR Plus using ZWO USB 3.0 cable).
Scope/OTA: C8 SCT with a 0.63 Reducer
No guide scope. No guide camera. My main use is EAA.
