HizerKite i am unable to get my ipad mini 4 to work with an Asiair plus....My wife’s ipad connects instantly
Richard,
Did you give Local Network access to the ASIAIR app in the iPad mini?
Open the iPadOS Settings, on the left panel of the Settings window, scroll down until you reach the apps section, and you should find the icon for the ASIAIR there. Tap on it, and the right panel should show the Settings for ASIAIR.
There is a Local Network toggle switch in the ASIAIR Settings -- toggle that on.
If you also want the iPad mini to send its location, be sure to also turn on the Locations property in the ASIAIR settings.
