There is conflicting information in the above cameras manual it states the above camera has a AR IR cut window but the website specs says it does not. I have bought a 2 inch ZWO IR cut filter to be used with this camera because I was sure that it did not have a IR cut filter window just the AR window. Which is correct???Mark
Where is the best place to install this filter?
