That's mean you are going to release a FW update for the ASI120MM?
I hope soon, for me it's important it works fine with Maxim via ASCOM driver
no firmware update.
ASCOM driver only, just updated it
you can redownload and test
the same link
http://zwoptical.com/software/ASICamera%20ASCOM%20Setup%20test.exe
Please look to the attached screens and find that the maximum is more than 4096 ( 12 bits) and if binning set to 2 hangs up!?
Sam wrote:no firmware update. ASCOM driver only, just updated it you can redownload and test the same link http://zwoptical.com/software/ASICamera%20ASCOM%20Setup%20test.exe
This version works much better, but when changing the binning it hangs like the normal version (waiting for the video frame to catch up), and then works perfect.
Thanks and good job!.
we will try to fix the bin2 switch problem
Here is the newest ASCOM driver
welcome test and feedback
http://zwoug.org/viewtopic.php?f=17&t=1856
