Tech@ZWO Yes, back focus length of all ZWO cameras is optical
When there are other spacers in between the OTA and the camera, what you are referring to is not called back focus. It is usually called Flange Focal Distance.
Back focus is the property of a lens (like the back focus of a reducer), while flange focal distance has to do with the camera.
Back focus is the required distance of the metal back of an OTA to the sensor, while the flange focal distance is the distance from the camera flange to the sensor. They are only the same if there is no spacer in between the OTA and the camera, e.g., using a Canon EOS lens with 44mm back focus, and a Canon EOS camera with 44mm flange focal distance.
http://camera-wiki.org/wiki/Flange_focal_distance
https://briansmith.com/flange-focal-distance-guide/
The formal name of back focus is "back focal distance." See for example, page 15 of John Greivenkamp's [RIP] Field Guide to Geometrical Optics, SPIE, ISBN 978-0-8194-5294-8. I think that if you are an SPIE member, you can get the book at a small discount.
Front focal distance of an astronomical telescope is at infinity.
