Can one use the ASI 120 mc-s as the imaging camera and perform all Sky polar alignment with it on the ASI AIR? Using a Celestron 8 Edge on an AM5 I'm unable to see any stars in preview, though I got well focused on the moon.
Borregan The FOV range of ASIAIR Pro and Plus plate solve is 0.2-33 degrees, this combination is out of the range, so can't PA on ASIAIR.
The FOV will be tiny because of the small sensor size so it will not plate solve.
Thanks for the responses.
