Njp Does it set the camera temperature to -10c or does it set it to -10 degrees centigrade below the current ambient/measured temperature outside.
Target of -10ºC at the sensor, of course. A ∆ of 10º is useless since the images willl be taken at a temperature that is different from the temperature that you took your dark frames.
Try to set the temperature to keep the cooler power below about 90% since that will also affect how constant the temperature is kept through the duration of your imaging session (on top of the propensity of ZWO's cameras to leak oil from the thermal pad when stressed). That consideration could influence whether you want to take dark frames indoors (except with the camera in a refrigerator).
