Issue was corrected, seems that some Home WiFi's are just a pain in the rear.
I had this same issue with some Blink Devices.
Simple fix was to connect to my iPhone HotSpot using my iPad.
Once I did this I was able to get an IP address on the iPad and then connect ASIAIR to my AM5 Mount .
I think this issue happens when you have more than 1 WiFi Router in use. Although I not sure why one did work fine.
Thank you ZWO Support (Simon Lewis),
NoDarkSkies
