EFRIDAY My C11 Edge has much too small a FOV for the ASIAIR to plate solve directly. Is it possible to load RADEC coordinates directly into my AM5 mount (obtained, say, from Astrometry.net) and force the mount to Sync ?
Remember that plate solving has nothing to do with the mount.
"Plate" refers to a photographic plate that is used by astronomers even not too long ago, like the plates on the View Cameras.
"Solve" simply means that you use the pattern ("asterisms") of the stars in the plate and use them to match with the asterisms in a database. ASIAIR itself uses a digested version of the database from atrometry.net -- but the digest is not the full database, and don't have sufficient asterisms to solve for a smaller area of the sky (i.e., smaller FOV of a small sensor/longer focal length telescope).
So, yes, you can take a JPEG, PNG, TIFF or FITS file from your camera, and send it to astrometry,net so they can use their full database. If you are not a paid user, you need to be willing to stand in line for their limited computer resource, and it could take 30 seconds to a minute to plate solve. I would suggest a small 8 bit PNG or JPEG to make uploading faster.
The plate solve tell you what the center of your camera sensor is pointed to in the sky.
The solved coordinates are useful for a number of things (if you want to tell someone else of a new comet that you have discovered, for example). It includes telling you mount where the camera is actually pointed (that is called "syncing the mount.")
You can sync your mount to the coordinates that are solved by astrometry.net. Depending on the quality of your mount, you may have to repeat this a number of times to get arc-second type accuracy.
