bluespeck Can I run ASIair on a standard Mac operating system
Depends on your hardware.
When you open the App Store .app application and do a search for ASIAIR, do you see a tabbed switch that says "Mac Apps" and "iPhone and iPad" apps at the top?
If you do, it should list ASIAIR app under the"iPhone and iPad" tab. If not, your Mac is not using the Apple "M" series processors, and there is no way to emulate the ARM instruction set to run the ASIAIR iOS app.
Keep in mind that some ASIAIR functions (like pinch zoom) are not available if you only have a mouse. You need a track pad on your Mac to pinch zoom.
