GaryQ All are empty except for the Autorun, which has the images I took.
It is odd, since the AutoRun log is also saved in a log folder.
If there is no AutoRun log, I am not surprised there is no PHD2 log either. Most of the complaints I read have to do with missing PHD2 logs, not missing AutoRun logs.
Try again, and make sure that you have stopped AutoRun properly. When you enter the AutoRun schedule (using the "hamburger" icon from the main AutoRun window), you should see the place where you can add (big + sign) a sequence. At the top right corner you will see an "restart/reset" icon -- an almost full circle with an arrow at the end. Tap on that to properly terminate an AutoRun sequence.
Next, soft dismount the USB storage, by choosing some other storage, like the microSD or eMMC storage. And just to make sure, do a soft shutdown of ASIAIR from the ASIAIR Settings window (the one that looks like a WiFi icon). And only then unplug the USB storage. This will make sure all files are written and closed.
If it works, you can then figure out which step you can avoid doing. But I always do all the above steps.
