Hello, I borrowed an ASIair Pro from a friend for testing purposes, and almost everything is working as expected, it's an amazing device.
But I'm having issues with the Station Mode: after I enable Station Mode to connect it to my home wi-fi, I'm not able to connect to it anymore. I tried by connecting my phone to my home wi-fi and opening the ASIAir app, where I can see the device, but I can't connect to it, because I just get a non-stop spinning wheel.
And If I try to use the ASIair wi-fi again, I can't see the device, so I can't connect to it. Then, I get stuck in that screen no matter what I've tried, and the only way for me to connect back to it, is to reset the AA, reinstall the app, so I can use the ASIair wi-fi to connect to it.
Last test I did was using a wi-fi repeater, an connect the ASIair using an Ethernet cable, same result.
Any idea on how to fix this?
Thanks!
