the sensor on ASI120MM is much much better than SSAG.
So you will get a better result definilty
What is the aperture of this fisheye lens? that will help me do a better job of judging exposure times as well.
the aperture of the lens is F2. but the brigness of a star is mainly depends on the diameter of your guider scope instead of the aperture.
Also, when I am using the st4 cable from the camera to my mounts autoguider port should I select asi st4 ascom, usbst4, or On camera? So far I have only used the ascom connection.
just select on camera if you use the ASCOM driver.
more detail can have a look at here:
http://www.zwoptical.com/Eng/Cameras/ASI120/software_autoguider.asp
