I installed a 512GB SD Card and loading times are very very slow 1kb to 200kb and back to 1kb or never loads.
I put back in my 128GB SD Card and I am back to 1+MB loading size.
It seems to be a hit and miss. I did find out that after you setup station mode and connect the AM5 to the ASIAIR Plus
and set the IP in ASIAIR Plus for the Mount I then connect directly to ASIAIR Plus and it seems to work best.
But both ways work.
Thank you.
