Oren I can connect to the AAP Wi-Fi but when I open the app, no Asiair is detected.
Hi Oren,
On your iPhone, go to Settings (the same place you find WiFi settings and General Settings).
One the left side of the Settings window, scroll down, past Apple ID, Airplane Mode, WiFi, General, App Store, Passwords, etc until you reach the Apps Settings section.
There, among other Apps, you will find the ASIAIR app (alphabetically). Tap on the ASIAIR app icon.
ASIAIR App Setting will appear on the right side of the Settings window.
You will find a Local Network permissions toggle switch.
Toggle it on.
Also, you might as well also change Location permission to "While Using," otherwise you will not be able to sync the iPhone's Longitude to the ASIAIR.
Relaunch ASIAIR app, and you should be able to find the ASAIIR device, and connect to it.
Unless you are connected through the ASIAIR LAN (Ethernet RJ-45) port, you need to connect to the ASIAIR WiFi hotspot first (select the ASIAIR SSID in the iPhone's Wi-Fi settings). But you probably know this already since you had connected with your iPad.
From there, you can use the ASIAIR app to tell the ASIAIR device to change to Station Mode, etc. Again, my apologies if you already know this.
At any one time, the ASIAIR device will only allow up to two tablets/phones/computers to connect to it. If you already have two iPads connected to it, disconnect at least one of them first.
