Out of curiosity, I just tested the EFW again (connected to Mac and one of the ASIStudio suite).
Looks like the stutter only happens when trying to move 6 slots. It can go directly to a hole 5 slots away without any stop in between.
So, it is in a sense, more similar to your problem than I originally thought -- i.e., only a 6 hole movement causes a "problem."
Must be something that keeps them from reaching a destination that is more than 5 holes away. And the firmware version of mine could be a bug-fix version of what you have. It still won't get there non-stop, so it breaks the movement up into two, with a pit stop in between?
P.S., just tested a 7-hole 36mm ZWO wheel, and it does the same pit-stop thing when asked to move 6 holes.
