vschneck Does this mean I need to wait until the next release of ASIAIR app, or is there a way to use the beta release?
https://testflight.apple.com/join/yAuk7e7Z
Be sure you know how to revert your ASIAIR firmware to the factory default before attempting to download the Beta, since that may be the only way for you to end up with a functional ASIAIR v2.0 in the case that the Beta has some bug that you cannot work around.
Or, you can submit your image to astometry.net's nova portal here:
https://nova.astrometry.net/upload
astrometry.net will plate solve the center of the plate for you. If your internet uplink is slow, first convert the file to an 8 bit JPEG or monochrome PNG file.
