Hi, I purchased a PE200 for use with an AVX 2" tripod, however, the adapter plate is not suitable for the tripod hole due to non-matching diameters. The tripod hole has a diameter of 60.5-60.7mm, while the adapter diameter is 61mm. What to do?
You must be the first buyers of PE 200. You can contact your dealer and we will send you a new adapter, which is 59mm in diameter.
ASIMount@ZWO Did u make one for the eq6r pro yet?
CROWJO you mean skywatcher 1.75" tripod?
@ASIMount@ZWO Any plans to sell the Skywatcher Adapter for PE200 mount separately? I have the old extensions for AM5 (two 3" blocks you were selling). I would like to use them with my skywatcher tripod.
Thanks.
