I'm hoping/planning to purchase an AM5 primarily for visual use with a Mewlon 210. That's a 210mm OTA, but these are long for a 210mm diameter tube at 700mm. And...I strongly prefer to use it in Alt-Az mode since I'm doing visual.
Would this OTA have a rocking or vibration issue in this situation? Measuring the total weight with dovetail, 2" diagonal, and Ethos EP it comes to 11kg. Should I perhaps use a very light counterweight, or would that help?
Lastly, has anyone mounted this to a Losmandy LW tripod? The one that comes with the GM-8. I find this tripod incredibly stable. It has a center bolt hole and there are adapters available since I would use it with an extension. Would attaching the AM5 with the single bolt on this tripod be adequate? I currently use it with a DM-6 Discmount with the tripod at maximum height and a 12" extension and it's solid!
Thanks for any (relevant!) replies!
