Auto-solve stopped working any ideas?
Cold be similar to my problem I'm using a filter, and the auto solve exposure is not long enough to find enough stars to solve. If you are using a filter/drawer, try removing the filter before solving.
johnrsims43 Thanks but it s not even trying to plate solve, it was working fine in the past, if I see the target in preview image and I press on it and the green go circle appears, after I've pressed it it centres and auto solves then.
Brendan You have to enable "Center on target" in the mount menu.
Fantastic thanks its all working now, just puzzled as to why it suddenly switched itself off.
