Hi,
My set up is:
AsiAir Plus (tried both the V2.0 and V2.1 with the respective Firmware)
Star Adventurer GTI (also used the 3.44 and the latest 3.45 Firmware)
Guide Camera Zwo Mini 120mm (connected to the AsiAirplus)
Main Camera Sony A7III (connected to the AsiAir Plus)
I've tested both the USB-B to USB2 Cable as well as the EQMOD (Cable RJ45 to USB2) for connecting the AsiAir Plus to the SA GTI.
So, now to the problem, the ASI app starts good, I can connect easily the camera (in V2.1 version, obviously not in the V2.0 version), the Zwo Mini as a guidescope and the mount (EQMod Mount selected).
Now: whenever I control with the arrow buttons the mount, it first works maybe once or twice I touch them but then the mount doesnt stop slewing. Same issue when I Goto to a deepspace object it just starts slewing but never stops and I cannot cancel it - the SA GTI does not stop.
When I just use the Syncscan App to control the SA GTI it works just fine, no issues at all so it must be the AsiAir Plus.
I'm honestly at the end of trying everything out and it's a great disappointment until now. Any tips, is the Asiair Plus just broken?? I've purchased it new just a few weeks back, it was unopened.
Thanks for your help!
I
